 Post subject: S.Y.E.Question
 Post Posted: Fri Oct 20, 2006 12:30 am
Quick question, does basicaly everyone here who has a lifted jeep use a S.Y.E. and a C.V type drive shaft or is it possible to use a normal drive shaft just lenthend? I'm thinking 3'' possibly 4'' lift and 33'' tires on a 89 cherokee any ideas or sugestions, thanks
89 camo cherokee
77 CJ5
80 blazer
02 silverado2500 hd
 Post subject: Re: S.Y.E.Question
 Post Posted: Fri Oct 20, 2006 1:00 am
you should be fine. I ran a stock unit with a spring over for a while. The spring over netted me 5.5" of lift. Then i changed the axle and installed an extreme sye.
ANyway... you should be able to lift it 4" and use the stock stuff. hell go for it, and see what happens.
 Post Posted: Fri Oct 20, 2006 2:25 am
Yep. What he said.
 Post Posted: Fri Oct 20, 2006 8:23 am
Same here, i've run a spring over (about 6") and i had the rear shaft lengthened 1", it's worked fine...my only problem is keeping Tranny mounts...when i hit bumps and send the entire axle up (compression) i run out of room in my slip yoke, and it bottoms out, which transfers that vertical load to my transfercase output, which in turn rips out the tranny mount....
 Post Posted: Fri Oct 20, 2006 9:31 am
Same here. Had a little vibration, but no major problems... until that tree.
 Post Posted: Fri Oct 20, 2006 10:04 am
When i did my 4" on my YJ i had alittle vibration and was drivable, did the SYE and it was no longer drivable with rear drive shaft in, had to turn pinion up
 Post Posted: Fri Oct 20, 2006 10:33 am
Oh yeah, I had my pinion turned up when I got the SOA so that was already done.
 Post Posted: Fri Oct 20, 2006 11:33 am
Yup, pointed my pinion at the T case too...
 Post Posted: Fri Oct 20, 2006 4:29 pm
Deacon Dr. Brown Valentine
not sure with the responses so i will make this statement. maybe i miss read what he was asking about.
cherokee not sure but if it is a TJ then yes get a SYE
skid => '97 Jeep Sport
SYE, 2" Suspension Lift, 1" Body Lift, 31 x 10.5 work week (33x12.5 playing)
Brush Grill , T-Max 10k HD Winch
150watt 380,000/each candle power driving lights
 Post Posted: Fri Oct 20, 2006 4:39 pm
Alan got a 4" lift for his Cherokee, and the SYE was definetely needed.
 Post Posted: Fri Oct 20, 2006 6:59 pm
just depends, some need it and some do not. get yer lift and put it on, if there are unbearable vibes, get driveshaft. this is a trail only rig right? i'm not too sure if you can fit 33's with a 3-3 1/2 inch lift though with out cutting. not too sure about that... not that cutting is a problem. by the way... i still like your exhaust. that is one helluva way to do it.
 Post Posted: Sun Oct 22, 2006 11:44 am
Also I was thinking about putting a 8.8 in the rear and I heard some where that the 8.8 pinion housing is about 1'' longer than the dana 35 so if you got a adaptor u-joint you should be able to be adjusted for your lift right? And it is strickly a trail rig. Any insight???????
89 camo cherokee
77 CJ5
80 blazer
02 silverado2500 hd
 Post Posted: Sun Oct 22, 2006 2:57 pm
Combo joints are no good in my opinion. Who will have a spare?
 Post Posted: Sun Oct 22, 2006 6:30 pm
ask scout man about combo joints...
 Post Posted: Sun Oct 22, 2006 7:13 pm
on a cherokee if you have the stock driveshaft lengthened you are good to go without an sye to at least up to 4 to 6 inches of lift. years ago i ran mine this way, i had a clunk with this set up. i thought it was the drive shaft, turns out it wasn't and i could've run without the sye for a long time. if you do eventually decide to go with an sye, for a cheap setup i have ran the RE hack and tap for years (to this day even), without any problems whatsoever...
i would put the 8.8 in, with the inch in extra length, try the stock driveshaft with the combo joint and see where you are at. combo joints are stock factory stuff in broncos and such and pretty dependable. they are common at the usual auto parts stores...i would just keep a spare on hand like you would with any other ujoints. try it and see how it does.
mac 'i know yer all about the cheap' gyvr
 Post Posted: Mon Oct 23, 2006 8:18 am
good call mac 'insert something fun here' gyvr
 Post Posted: Mon Oct 23, 2006 8:19 am
greasy gizzard-juice
Well isn't that something smart to carrry with ya? :?
:flipoff:
Check out my woman's webpage so she'll be happy lol. If ya need photography work done this is the place to get it.
http://iwant2shootu.com
 Post Posted: Wed Oct 25, 2006 12:19 am
:flipoff:
my point...
mac 'preachin to the choir' gyvr
Users browsing this forum: No registered users and 11 guests
