Post new topic Reply to topic  [ 14 posts ]
 Post subject: transfer case
 Post Posted: Fri Oct 20, 2006 10:28 am
I have two ? in one;
1) do transfer cases get any fluid supplied from the transmission?
2) if not how bad is it if they are over filled?
I was checking the fluids and got covered when I pulled the fill plug on the transfer case. According to the owners man. it's supposed to be at the bottom of the fill plug.
Thanks
Jon
 Post subject: Re: transfer case
 Post Posted: Fri Oct 20, 2006 10:38 am
Thanks
t-cases do not get fluid from tranny, you do not want to over fill the tranny to much if its much more than a half of quart or maybe quart i would drain some out, and when filling t-case you fill till it starts to come out of the top plug
 Post Posted: Fri Oct 20, 2006 11:34 am
Is the fluid clear red? If not, you have contamination. Drain and refill with any decent ATF (assuming you have NP231).
'02 TJ - not stock.
 Post Posted: Fri Oct 20, 2006 11:58 am
I'm with him...if it's that high, i imagine water came in through the vent hose...drain and refill
 Post Posted: Fri Oct 20, 2006 12:06 pm
so if it looks like a milk shake, you that might be bad....joking
 Post Posted: Fri Oct 20, 2006 12:53 pm
over full is an understatement!! I think the t-case has been replaced, it's cleaner than the transmission. I'm guessing 5 qts. came out before I put the fill plug back in. I do need to change it, it's not red any more.
I don't know if it's a NP or NV t-case, it's in that p.o.s. Blazer.
Jon
 Post Posted: Fri Oct 20, 2006 1:14 pm
Your saying 5quarts came out off the t-case before you put plug back in, cuz it should only hold like 2 maybe 2 and half, and i believe the blazer has a NP231C, which has a different input shaft than jeeps NP321 other than that they are they same
 Post Posted: Fri Oct 20, 2006 1:58 pm
that is correct. When I put the plug in it was just barely dribbling out. What type of fluid do you recomend?
Jon
 Post Posted: Fri Oct 20, 2006 2:05 pm
i use BG synthetic oil Synro Shift Lock 2, any kind of manual tranny fluid like a ATF or something would be fine, i use the BG stuff cuz its FREE to me(sponsor)
 Post Posted: Fri Oct 20, 2006 2:36 pm
Thanks!!
Jon
 Post Posted: Fri Oct 20, 2006 2:44 pm
 Post Posted: Fri Oct 20, 2006 4:33 pm
Deacon Dr. Brown Valentine
you did pull the top plug right :-)
skid => '97 Jeep Sport
SYE, 2" Suspension Lift, 1" Body Lift, 31 x 10.5 work week (33x12.5 playing)
Brush Grill , T-Max 10k HD Winch
150watt 380,000/each candle power driving lights
 Post Posted: Fri Oct 20, 2006 4:52 pm
Good form.
 Post Posted: Fri Oct 20, 2006 5:11 pm
Yes I did :tu2:
Jon
