 Post subject: Pinion Angle
 Post Posted: Fri Feb 23, 2007 12:10 pm
Deacon Dr. Brown Valentine
Hey what is the pinion angle for a stock TJ?
skid => '97 Jeep Sport
SYE, 2" Suspension Lift, 1" Body Lift, 31 x 10.5 work week (33x12.5 playing)
Brush Grill , T-Max 10k HD Winch
150watt 380,000/each candle power driving lights
 Post Posted: Fri Feb 23, 2007 2:12 pm
< 0
 Post Posted: Fri Feb 23, 2007 2:18 pm
so for every inch of lift do you know what it changes?
 Post Posted: Fri Feb 23, 2007 2:27 pm
No...that was supposed to read "greater than 0" in other words...i was being a donkey
 Post Posted: Fri Feb 23, 2007 2:29 pm
But i've heard some things....like you'll be fine if you have no more than 7 degrees of difference between the u-joint angle at the top of the driveshaft vs, the angle at the bottom (pinion) of the driveshaft....i always just point the dang thing at that output of the tcase and let it be....
 Post Posted: Fri Feb 23, 2007 2:33 pm
But you wrote "less than" 0.
 Post Posted: Fri Feb 23, 2007 2:34 pm
the problem is that a friend put in a cherokee axles in his ranger after blowing the rear end. he was wanting to know what he could get a way with.
http://www.zabeard.com/vids/Zach%20Stuck%202.wmv
 Post Posted: Fri Feb 23, 2007 3:18 pm
That only works for a Double Cardan style shaft. You want to keep the angles as close to equal at both ends so that the u-joint vibrations cancel each other out. The farther you go from that, the more vibrations you are going to get. Either raising the motor up, or lowering the transfer case lowers the angle of the tcase output, allowing you to turn up the rear axle to match the angle. Best bet is to set it up as close to this ideal situation as possible, if you have vibes, you need to set up a double cardan style shaft.
 Post Posted: Fri Feb 23, 2007 9:11 pm
Also, set the yoke at the diff 2 degrees lower, to compensate for the pinion wanting climb the ring gear.
