Board index » 4x4 Related Technical Forums » Misc 4x4 Tech
Post new topic Reply to topic  [ 13 posts ]
 Post subject: Low Oil Pressure
 Post Posted: Wed Mar 21, 2007 6:39 pm
My oil pressure gauge has always read really low and I thought it was just the gauge which has never really worked but my lifters have started to clack around alot. What all can cause a low oil pressure? I bought this engine as a remanufactured long block about 50,000 miles ago and it's just starting to get really bad. The oil pump was replaced with the new motor.
My gauge reads really high at startup (around 60-70 psi), then as I drive it will slowly sink down to near zero as it warms up. Not sure if this is typical of a certain failure. It does leak a little oil out of the back and I'm not positive whether it's the oil pan gasket or the rear main.
 Post subject:
 Post Posted: Wed Mar 21, 2007 7:03 pm
Sounds like a pump to me. If the problem had ALWAYS been there, I'd think a plug was missing in the crank journals.
 Post subject:
 Post Posted: Thu Mar 22, 2007 3:57 am
pull the pan...
check the main bearings with plastiguage...
if they check out then replace the pump...
otherwise almost sounds like main bearings to me...
mac 'i'd replace the bearings and the pump if it was mine' gyvr
 Post subject:
 Post Posted: Thu Mar 22, 2007 8:37 am
macgyvr wrote:
pull the pan...
ditto
 Post subject:
 Post Posted: Thu Mar 22, 2007 9:58 am
Or do what I did... run 50 weight and trade it off!
 Post subject:
 Post Posted: Thu Mar 22, 2007 10:48 am
If it ain't knockin don't worry about it. :tu2:
 Post subject:
 Post Posted: Thu Mar 22, 2007 11:33 am
greasy gizzard-juice
macgyvr wrote:
pull the pan...
ditto
Thanks for writing it for me Mac.
Check out my woman's webpage so she'll be happy lol. If ya need photography work done this is the place to get it.
http://iwant2shootu.com
Hell who knows what I'm gonna have from one day to the next so why bother trying to list em.
[/img]http://i41.photobucket.com/albums/e252/crazy_cooter56/jeeps2.jpg[/img]
 Post subject:
 Post Posted: Thu Mar 22, 2007 11:37 pm
crazy_cooter56 wrote:
macgyvr wrote:
pull the pan...
ditto
welcome...
i learned that bearing going out/nearly gone, will show good pressure when the oil is cooler and thick...then as the oil gets warmer, the pressure goes down...i traded a vehicle in one time with this condition...just had to not let the dealer take it for a very long test drive...
mac '15-45 or 50 wt old will hide the problem somewhat too' gyvr
 Post subject:
 Post Posted: Fri Mar 23, 2007 12:02 am
macgyvr wrote:
pull the pan...
ditto
welcome...
sounds like my TJ...
 Post subject:
 Post Posted: Fri Mar 23, 2007 8:59 am
I had that once, turned out to be cam bearings.
 Post subject:
 Post Posted: Fri Mar 23, 2007 2:13 pm
Thanks for the help guys, I'm going to dig into it tomorrow hopefully. Can a leaky rear main cause low oil pressure? I guess I just don't know where the pressure is developed in the engine.
 Post subject:
 Post Posted: Fri Mar 23, 2007 4:22 pm
not usually...but it is a jeep...
oil pump and bearings keep the motor running...
mac 'its a jeep' gyvr
 Post subject:
 Post Posted: Sat Mar 24, 2007 4:04 pm
Older Ford's are notorious for these exact symptoms. Especially the 351 and 400M's. Had a couple of them that would have great pressure upon starting but within a few minutes it was nearly nothing. Both of em spun a bearing and locked up.
Users browsing this forum: No registered users and 8 guests
