 Post subject: Dana300 rebuild
 Post Posted: Mon Aug 20, 2007 4:02 pm
So whats the best way to put the center "idler" gear back into a Dana300...it's got about 50 needle bearings a couple plates and some rings...how do you put it all together at the same time?
 Post Posted: Mon Aug 20, 2007 8:42 pm
Just kind of like "Viola!"
 Post Posted: Tue Aug 21, 2007 7:12 am
"Viola!"
But i don't see any cookies!!
 Post Posted: Tue Aug 21, 2007 7:53 am
"Viola!"
I like turtles
 Post Posted: Tue Aug 21, 2007 9:35 am
"Viola!"
I'm guessing we had the right thing going sunday, sticking those shims in with grease, and the broom handle to hold the bearings, you may try the freeze method and stick that center idler gear assembly in the freezer. to shrink it slightly.
 Post Posted: Tue Aug 21, 2007 10:46 am
"Viola!"
But then it'd be cold... :-D
 Post Posted: Tue Aug 21, 2007 11:13 am
"Viola!"
gloves
 Post Posted: Wed Aug 22, 2007 12:06 pm
"Viola!"
And we don't have ANY room in our freezer....it's full of beef....we bought a cow MOOOOOOO
 Post Posted: Wed Aug 22, 2007 11:04 pm
"Viola!"
um, have a cook out?
 Post Posted: Tue Aug 28, 2007 3:25 pm
Sooooo i got it back together last night...actually went together on the first try!! I greesed everything with axle greese so the needle bearings wouldn't move around a lot. To install the needle bearings i cut a piece of closet rod (wooden dowel about 1 1/8 diam.) and stuck it in the hole...then put each needle bearing in the hole one at a time, put the two "rings" on, one on each end of the open hole, then i "glued" the outter washers to the transfer case casing (on the inside) and it all slid to gether with little trouble...i was actually surprised...i thought i'd be there for hours...i then scraped all the gasket surfaces down and applied a lite layer of RTV silicone, tonight i'll add fluid.
 Post Posted: Wed Aug 29, 2007 2:12 am
So basically what we tried when I was there, only with alot more grease?
Told ya, grease is good stuff!
 Post Posted: Wed Aug 29, 2007 7:46 am
Movie quote "this is glue....stroong stuff"
