Post new topic Reply to topic  [ 15 posts ]
 Post subject: Bolt pattern
 Post Posted: Mon Aug 04, 2008 9:17 pm
How do you measure bolt pattern? I have some wheels that I am curious if they will bolt up to the XJ, if I ever get one.
Sprite
'88 XJ- 3" Rough Country, 4.0L, auto, cb
'01 Cummins- leveling kit, air bags, full DTT tranny, edge box, BHAF, AM rear end
'96' ZJ- stock
 Post subject: Re: Bolt pattern
 Post Posted: Mon Aug 04, 2008 11:05 pm
i believe it is center of bolt to center of bolt, as close to across as possible.
 Post Posted: Mon Aug 04, 2008 11:08 pm
You could probably take it to a tire and wheel shop and they could tell you also.
 Post Posted: Tue Aug 05, 2008 6:57 am
Yup...so in the case of a 5 lug rim, you're measure across 2 holes, skipping 1. Try to either measure from far edge to close edge, or center to center (eyeballed)
by edge to edge, i don't mean the shortest distance, i mean measure from the same edge of each hole....does that make sense, like if i was measuring studs 16" on center, i wouldn't measure to the center of the stud cause there's not an edge there marking where the center REALLY is. So i measure from leading edge, to leading edge of the next one, and put that edge at 16...so therefore the centers are at 16....make sense?
 Post Posted: Tue Aug 05, 2008 5:49 pm
Yup. I think I get it. I got what I think is 4.25". What are XJ's? i know it is probly various but give me a ball park figure.
Sprite
'96' ZJ- stock
 Post Posted: Tue Aug 05, 2008 6:48 pm
XJs/YJs/ZJs/TJs are all 5 on 4.5
 Post Posted: Tue Aug 05, 2008 9:18 pm
Is there such a size as 5x4.25" or is my measuring tape just a little off?When I bought them they were bolting onto a 93' Mazda Navajo for those of us with the ability to look that stuff up that would be great.
Sprite
'96' ZJ- stock
 Post Posted: Tue Aug 05, 2008 11:24 pm
It could be metric...
Why don't you just try and bolt one on and see?
 Post Posted: Tue Aug 05, 2008 11:30 pm
Quick Google Search:
MAZDA NAVAJO 2WD, P/you 2WD & 4WD 1977-1995 6x139.7
So according to that, they are metric, and are 6 lug..... so no, they won't work...
Source: http://newsgroups.derkeiler.com/Archive ... 00010.html (it has bolt batterns for just about everything)
 Post Posted: Wed Aug 06, 2008 5:46 am
Well I can shoot that down right away cuz there 5 lug. There must be another ,odel there or something. I would try them but I don't have a Jeep so it makes it hard. Wait! my Dad has a 96 Grand Cherokee will that work? I forget the code for it......ZJ WJ or somethin.
Sprite
'96' ZJ- stock
 Post Posted: Wed Aug 06, 2008 2:24 pm
Sprite
Yep... your dad's ZJ will work, should be the same pattern.
 Post Posted: Wed Aug 06, 2008 11:50 pm
kennedy you wrong s.o.b. The navajo is the twin to the Exploder, which has the same bolt pattern as your zj, xj, mj, tj, yj.
 Post Posted: Thu Aug 07, 2008 3:14 am
hey... I just went off of that website... should have known it would be bad considing "toyota" is in the URL...
 Post Posted: Thu Aug 07, 2008 5:36 am
Haven't had time to check it out maybe today.
Sprite
'96' ZJ- stock
 Post Posted: Sun Aug 10, 2008 3:50 pm
Yup finally found some time to check it out and they bolt right up. Now I have to decide between buyin an XJ or finding a dakota to trade for my Dad's ZJ. Which one would you guys go with? I will move this topic.
Sprite
'96' ZJ- stock
Users browsing this forum: No registered users and 9 guests
