Board index » 4x4 Related Technical Forums » Misc 4x4 Tech
Post new topic Reply to topic  [ 13 posts ]
 Post subject: needing an alignment
 Post Posted: Thu May 12, 2011 5:02 pm
batman
Anyone know of a good place in the fort to get an alignment on my?
 Post subject: Re: needing an alignment
 Post Posted: Thu May 12, 2011 5:26 pm
on your what?
mac 'could make a difference' gyvr
 Post Posted: Thu May 12, 2011 5:34 pm
batman
on my 86 comanche. I got the front axle back under it but havent gotten an aligment done yet. Its got a 3 inch lift under it.
 Post Posted: Thu May 12, 2011 9:44 pm
I take my 3 to Firestone at Southtown. I bought the lifetime alignment which is great if you're going to keep the truck a while. I wouldn't let them try to talk you into anything else though as their rates seem steep. They wanted $14 to replace a side marker bulb. They also wanted $350 to replace a worn steering rack bushing. Part cost $17 from GM and took me about an hour to install. Stick strictly to the alignment, though, and I'd have no problem recommending them.
 Post Posted: Thu May 12, 2011 10:11 pm
tape measure for a jeep...
mac 'what are your concerns?' gyvr
 Post Posted: Thu May 12, 2011 10:13 pm
tape measure.... or go to Todd Bennets in new haven.
 Post Posted: Fri May 13, 2011 6:00 am
I have always used woodward tire on covington rd. . Locally family owned, they all work there. They will do odd vehicles with non stock suspensions. They won't warranty anything outside factory spec but if you have all of the proper parts they will set an alignment anywhere you want it.
Frankley though with a lifted big tire jeep some tape measures and or maybe some strings. Then some time.
 Post Posted: Fri May 13, 2011 9:22 am
I'd try it at home if possible. Save yourself the $50. There's not much that's adjustable aside from toe in/out anyway.
 Post Posted: Sat May 14, 2011 8:41 am
batman
I have never done it with a tape measure before.
 Post Posted: Sat May 14, 2011 6:44 pm
http://www.4x4xplor.com/alignment.html
 Post Posted: Sat May 14, 2011 6:58 pm
batman
Thanks I will have to try that after I figure out why I cant turn as far to the right as i can the left and recenter my axle.
 Post Posted: Sun May 15, 2011 2:36 am
track bar?
mac 'still got my number?' gyvr
 Post Posted: Sun May 15, 2011 6:35 am
batman
I need to relocate my hole for my track bar so the axel lines up under the jeep.
Users browsing this forum: No registered users and 4 guests
