 Post subject: A/C help....
 Post Posted: Tue May 30, 2006 11:38 am
So this is for my '00 F-250 Powerstroke. It blows cold, then it'll blow warmish air, then back to cold, but in no particular pattern...any help?
 Post subject: Re: A/C help....
 Post Posted: Tue May 30, 2006 1:01 pm
if it has a vaccuum regulator behind the dash, this controls the a/c, check the hoses going to it.
check and see if the compressor is kicking on and off at the same rate as the warm/cold issue. You could be low on refridgerant, and the low pressure switch is kicking off...
being a 2000 it should be 134a refridgerant. you can buy that stuff at walmart. add a half can and see what happens. DO NOT breathe the stuff, it causes testicular cancer. (not a joke)
 Post Posted: Tue May 30, 2006 1:15 pm
Behind the dash....great...should be real easy to get to :-) hehehe thanks for the info john!
 Post Posted: Tue May 30, 2006 1:36 pm
if there is a vacuum leak going to the regulator, you should be able to hear it without taking the dash apart.
 Post Posted: Tue May 30, 2006 2:11 pm
yeah, cause my diesel with MBRP exhaust is quite at idle.....
 Post Posted: Tue May 30, 2006 3:41 pm
i would bet on the low freon first...
 Post Posted: Tue May 30, 2006 3:43 pm
I would bet there is no freon... Being a 2000 it should be r134a. :tu2:
 Post Posted: Tue May 30, 2006 3:49 pm
Which he stated once already...but must have forgotten....john, you feeling ok?
And a guy from "thedieselstop.com" said not to add freon/refridgerant because too much could cause problems too, i had never heard of that.
 Post Posted: Tue May 30, 2006 3:50 pm
Guess it's time to call grandpa....he still works on a/c systems for cars...i'm sure he'll have an answer for me....
 Post Posted: Tue May 30, 2006 5:07 pm
its a ford diesel, so doesn't it have an electric vacum pump? make that that is working too....
