Register    Login    Forum    FAQ
Board index » General Offroading Forums » Fabrication, DIY, Projects, Build threads
Post new topic Reply to topic  [ 37 posts ]
 Post subject: Project: Betty Bitch
 Post Posted: Sun Jul 26, 2009 5:54 pm
Web wheeler extraordinaire
Well, it has begun. After obtaining a set of 76/77 Bronco axles last September, I was finally able to get some time to start working on them.
Day 1:
With my trusty not-so-safe angle grinder, I cut the spring perches and shock mounts off the Ford 9 rear end. I then swapped out the discs and smoothed out the high spots.
Leftover brackets (anybody want them?).
This is something I found underneath one of the spring perch welds. No, I didn't maul the crap out of it with my angle grinder. This spot actually has quite a bit of weld on it still. I didn't want to make this one flush, as I don't want to make the hole bigger. It'll probably get filled up with weld when the new perches and shock mounts go on.
I got to start on the front Dana 44. These radius arm stops are going to take a very very very long time. After doing a bunch of reading, I was afraid that they were cast on. But after doing a bit of cutting, I'm through the weld on one side, and I see axle housing underneath it (very relieved).
In the end, it's only advice. Do whatever you like. :)
 Profile E-mail
 Post subject: Re: Project Betty Bitch Build
 Post Posted: Sun Jul 26, 2009 6:10 pm
Googled "deficate"
sweet!
 Post subject: Re: Project: Betty Bitch
 Post Posted: Sun Jul 26, 2009 9:22 pm
Nice!! :-) If you only had a torch....then you could blow through the axle housing like kennedy did to my first YJ....thanks dude....at least he had a welder on hand too!
'78 CJ7 project....
'00 F-250 Cranked up 7.3 powerstroke - tow rig
'98 Volvo V70XC 5 cyl turbo wagon for my wife
 Post Posted: Mon Jul 27, 2009 10:12 am
Originally, I wanted to have this done by the Turkey Run this year. But seeing as I haven't had much time to even work on anything, my new goal will be for the 2010 April Fools Day run. Here is my list of TODOs:
* Finish & install D44
* Finish & install Ford 9
* Belly-up w/ fabbed skidplate & crossmember
* Spring-over with 2" (or smaller) springs (depending on how the D44 goes) + removal of body lift
* De-rust and repair holes in body -- DONE
* Flat fender the front
* Herculine the inside
* Make new CB antenna mount and move to passenger-side (drive-through madness) -- DONE
* Fix tire carrier -- DONE
* De-rust and repair my doors (they are pretty bad) -- DONE
 Profile E-mail
 Post Posted: Mon Jul 27, 2009 10:28 am
bacon
'46CJ2a/buggy project in the works.
'08 Dodge 2500, 6.7 Cummins, 4x4
'81 Cherokee FSJ project
'78 GMC 4x4 short bed
www.HoosierTruckClub.com -join today!
 Post Posted: Mon Jul 27, 2009 12:02 pm
Nice! I have all of the CAD files for my skidplate etc. if you need any dimensions.
 Post Posted: Mon Jul 27, 2009 12:16 pm
poop pipe
Originally, I wanted to have this done by the Turkey Run this year. But seeing as I haven't had much time to even work on anything, my new goal will be for the 2010 Bunny Run. Here is my list of TODOs:
* Finish & install Ford 9 w/ locker
* Fix tire carrier
whats the 2010 bunny run? or is that the 2010 AFD run?
I wish my lawn was Emo so it would cut itself.
 Profile E-mail
 Post Posted: Mon Jul 27, 2009 12:51 pm
* Fix tire carrier
That's what I meant.. the AFD run. :doh:
 Profile E-mail
 Post Posted: Mon Jul 27, 2009 12:56 pm
That would be sweet! I'll PM you my email address.
 Profile E-mail
 Post Posted: Mon Jul 27, 2009 7:22 pm
Sweet meow I need to get my D44 done then we need to go bash our yjs on some rocks
Are you gonna tube fender the front or just cut it?
Just another YJ on 33's... 'Phat YJ'
Tow rig/Daily driver: 2004 Ford F-150..."Big Country"
The wife's Jeep: 2004 Jeep Liberty "Phat KJ"
 Profile E-mail
 Post Posted: Tue Jul 28, 2009 7:43 am
I'd prefer to tube it, but at the very least I'm going to cut them down a bit. I'm dying for some wheeling. It's been waaay too long.
 Profile E-mail
 Post Posted: Tue Jul 28, 2009 5:37 pm
sweet :tu2:
 Profile E-mail
 Post Posted: Sat Aug 01, 2009 2:01 pm
Day 2:
I managed to get the radius arm things and the coil spring perch removed. What I found interesting, is that I used 1 disc to remove everything on the Ford 9 and both radius arm mounts, but when I got to the coil spring mount it nearly ate an entire disc by itself! Also, the metal on the axle tube under the radius arm things looked like it had been laying on the deck of the Titanic. It took a bit to get all of the rust off of those spots.
I got a little deep on the radius arm thing cuts.
The leftovers from today. Alan, do you want these pieces?
 Profile E-mail
 Post Posted: Sun Sep 13, 2009 7:30 pm
Day 3: I've decided to drive it this winter until I get my axles 90% ready to go under. I got all of my tires dismounted, beads cleaned, re-cored, and rebalanced at Discount Tire. I even managed to talk them into putting a 31" inner tube in my spare that some jackwad had slashed back at my old house. I got it home, and started to work on some of its odds and ends.
Remember, the white wire on these means GROUND, the black and red are for the brake and tail lights. It messed with me a bit before I got it figured out. :)
To save wear and tear on the local drive-thrus, I moved my CB antenna mount from the driver-side to the passenger side.
 Profile E-mail
 Post Posted: Sun Sep 13, 2009 7:34 pm
Day 4:
Some of the rust patches that I've ignored for a couple of winters turned themselves into full-blown rust HOLES. I cut all of the infected metal out, and put the initial patch of fiberglass on them.
I wire wheeled several pounds of rust off of my frame and off of the bottom of my tub. I then slathered everything with metal ready and slogged POR 15 all over everything. It looks like the creature from the black lagoon crapped all over it.
I wrapped things up with an oil change and some fiberglass over the holes that were in my driver-side floorboard.
 Profile E-mail
 Post Posted: Mon Sep 14, 2009 8:47 am
ya look at tom gettin motivated! I like it. Looks good man. If you need help let me know bud.
 Profile E-mail
 Post Posted: Mon Sep 14, 2009 9:06 am
Did you get your turn signals functioning again? They look great!!
'78 CJ7 project....
 Post Posted: Mon Sep 14, 2009 5:51 pm
No i was over there the other night, he said something about a wire he needed to add I think heh. He will get it though.
 Profile E-mail
 Post Posted: Sun Sep 27, 2009 8:44 pm
Days 5 & 6: I got the other taillight in and installed an electronic flasher (which subsequently got my turn signals working).
I decided to treat my entire frame. I wire wheeled the whole thing off (thank God for a 2 inch body lift), metal ready'd all of it, and then gave it a healthy dose of POR15. The next day after the POR15 was nice and cured, I primer'd all of it, and then used several cans of hammerite on the whole thing. It looks a LOT better. :)
I was getting down to the wire (was going camping the very next day), so I was hurried in my bondo and touchup of my fiberglassed rust holes on the driver side. I ran out of time sanding / bondoing / sanding / bondoing, and decided to just prime and paint where it was so I could get it done. After I painted it, I realized how faded the paint on my Jeep had become. I'm going to have to paint the whole side so it doesn't look weird (after I get everything else done and if I'm still motivated).
 Profile E-mail
 Post Posted: Sun Sep 27, 2009 8:49 pm
Day 7: Anybody who has seen my doors knows that they are trying to turn themselves back into iron ore. They are in rough shape, and I don't want to buy new doors (yet). So.. I decided to knock the rust off the driver side door and fiberglass the (numerous) rust holes that had emerged. I had bolt and washer plugging the hole where the non-functioning lock once was. I removed it and got it with some fiberglass as well.
Yes, I deliberately ignored the window frame. The only thing holding it on in the back is a very thin badly-rusted piece of metal. I picked up my brother's mig welder the other day, and so I think I'm going to try to get creative with that at a later date. Until then, that corner is going to stay rotten.
 Profile E-mail
 Post Posted: Sun Oct 04, 2009 2:07 pm
Days 8 & 9: Worked some more on the doors. More fiberglass, more bondo.
I tried my hand at mig welding. I seem to have reinvented the booger weld on one side, and other other side seems like it's "ok". After it cooled I grabbed and pulled at it and it seems solid. I'm going to weld a bar across the back and then reconstruct that part of the doorframe with fiberglass. That should be fun. :)
 Profile E-mail
 Post Posted: Fri Oct 23, 2009 11:40 pm
Days ??? (I'm done counting the days).
I've mostly reconstructed the window frame, and have put an ungodly amount of fiberglass and bondo in numerous places. The door on the left has it's initial coat of POR15, and the door on the right has it's first (real) coat of paint. On both doors where I'm rebuilding the frames I'm still in the process of sanding, forming, refiberglassing, and bondoing. This is taking a LOT longer than I thought it would... which just motivates me more to not make it look like complete shit.
 Profile E-mail
 Post Posted: Sat Nov 21, 2009 5:45 pm
I finally got the doors wrapped up. They BETTER not rust for awhile. :)
I also got around to removing that ganky piece of plastic from where my cowl vent used to live. I cut a piece of metal from an old computer chassis and welded it into the cowl then bondo'd.
 Profile E-mail
 Post Posted: Sat Nov 21, 2009 6:29 pm
poop pipe
looks good tom. :tu2:
 Profile E-mail
 Post Posted: Sat Nov 21, 2009 11:07 pm
Thanks! It ain't perfect, but it's looking better than it did. :)
I started to work on the rust on my windshield frame, and to my dismay.. the ENTIRE bottom is rotten. I need a new windshield frame. :(
 Profile E-mail
 Post Posted: Sun Nov 22, 2009 12:06 am
poop pipe
why did you close off the cowl vent?
 Profile E-mail
 Post Posted: Sun Nov 22, 2009 1:54 am
bacon
hopefully not, you don't even have any metal left in them, do you?
 Post Posted: Sun Nov 22, 2009 1:55 am
bacon
word
Thats where the HVAC system gets its air...
 Post Posted: Sun Nov 22, 2009 9:00 am
I have no HVAC system. I have a marine heater for heat.. that's it. :)
 Profile E-mail
 Post Posted: Wed Nov 25, 2009 8:31 pm
Today was not a good day. I cracked my windshield in 2 places and spiderwebbed it in the passenger top corner. To top it off, my windshield repair job looks like complete and utter SHIT.
I don't have any pictures because I'm too pissed off about all of it.
 Profile E-mail
 Post Posted: Sun Nov 29, 2009 10:56 pm
Loves Tom's Neighbors
But you went wheelin anyways, and that's what counts!!!!!!
mac ' :2up: ' gyvr
TEAM BRANIK MOTORSPORTS Spotter #302 ROSCO
"BRINGING BACK THE BIG SPOTTER"
Branik Motorsports/Badlands Off Road Park
XRRA EAST COAST #518/#302/#08
Come TREC with US
 Profile E-mail
 Post Posted: Mon Nov 30, 2009 10:38 am
mac ' :2up: ' gyvr
It didn't help the cracks in my windshield any. :)
The good news is, that everything appears to be sealed up nicely. With all of the water and crap that was splashed up all over everything, my floor stayed dry all day (for the first time).
 Profile E-mail
 Post Posted: Fri Aug 20, 2010 5:15 pm
Ok.. pushing almost a year later, and I'm on the verge of some more upgrades. The wheels for my axles are in, along with numerous other parts.
I'll post pics later. :)
 Profile E-mail
 Post Posted: Tue Aug 24, 2010 9:59 pm
Hack the planet
such as?
 Profile E-mail
 Post Posted: Tue Sep 07, 2010 9:25 am
The axles are in! A huge thanks goes out to macgyvr for the use of his garage & skillz, as well as chaz, Alan, Brad, and Chris for their help. There were too many pictures to post in here, so the link is here:
http://www.poopworld.net/pictures/Anthology/September-2010/
I dropped off the front / rear driveshafts at Fort Wayne Clutch this morning as well as stopped by the Brake Parts place on Sherman. As soon as Stan returns my email, I'll have the ball rolling on the drag link as well.
 Profile E-mail
 Post Posted: Tue Sep 07, 2010 3:38 pm
bacon
sweet
 Post Posted: Tue Sep 07, 2010 8:17 pm
poop pipe
Looks great!!!! Good job, meow I got to get that shirt chris had....BSG
 Profile E-mail
Users browsing this forum: Earl and 1 guest
Jump to:
