Board index » 4x4 Related Technical Forums » Cherokee, Grand Cherokee, Comanche, Liberty Tech (Long wheelbase) » MJ Tech
Post new topic Reply to topic  [ 9 posts ]
 Post subject: radiator issues
 Post Posted: Sat Jul 23, 2011 9:22 pm
Anyone ever tried to put a larger radiator in the front of an MJ?
or should I just relocate it into the bed?
feedback requested advice required...
220deg F plus while wheeling is unacceptable B...
87 comanchee 6" lift, stroked 4L, built D44's spool rear, Arb front,
35" mud rovers, caged, tubed, 5point "required!!"
name "ant no cherry"
82 wrangler 4" lift, stock 4L, D35 lockrite rear, open front D30
mostly stock
name "the bucket"
 Post subject: Re: radiator issues
 Post Posted: Sun Jul 24, 2011 8:16 am
What fan setup does it have? Mecanical? What about an electric fan? Wonder if a v8 zj fan would fit?
 Post Posted: Sun Jul 24, 2011 7:44 pm
what is different in the setup of the truck from when it was stock?
mj's and xj's require every piece of the cooling system to be operating at top performance to stay cool. loose one of the components and you're running hot...
mac 'radiators, water pumps, and fans oh my' gyvr
 Post Posted: Mon Jul 25, 2011 9:38 am
batman
There are several companys that make radiators for the mj and cherokee with the v8 swap.
 Post Posted: Mon Jul 25, 2011 10:44 am
Sounds like you may also want to put lift blocks between the hood and the hinges to allow more air to escape from under the hood. and/or some hood vents...
 Post Posted: Thu Jul 28, 2011 8:12 pm
Question replays
4.0L replaced with 4.7L stroked
2 Hood vents out of Chrysler 7”X14” installed
Duel electrics 1,500cfm each, no mechanical
Lastly new duel core aluminum radiator????
HELP
mostly stock
name "the bucket"
 Post Posted: Thu Jul 28, 2011 9:11 pm
I hate to advertise another site on here, but you should check www.naxja.org. Lots of info over there on cooling as well as stroker builds. It could be so many things. I mean an xj/mj runs at 210 under perfect conditions.
mac 'some stroker guru's over there' gyvr
 Post Posted: Fri Jul 29, 2011 7:09 am
This is just a wheeler right?
Run water only in the system but remember to put in some coolant before winter. Use water wetter or I like tow cool from napa.
Run No thermostat.
Your running 2 fans. Are they pullers or pushers or 1 of each? Are they both on when your running hot?
Is your truck an automatic? If so run a seperate trans cooler maybe with fan of it's own and get the trans fluid out of the rad. Maybe an external oil cooler and maybe a fan as well.
Just some thoughts.
 Post Posted: Fri Jul 29, 2011 10:29 am
What donor vehicle did the engine come out of? Have you thought about maybe getting a radiator out of that same vehicle & making it fit somehow?
