Board index » 4x4 Related Technical Forums » Misc 4x4 Tech
Post new topic Reply to topic  [ 14 posts ]
 Post subject: What I wasted my money on and it didnt work!!!
 Post Posted: Thu May 21, 2009 8:37 am
I am sure we all have spent some green on a product, a performance part, and synthetic fluid
- ceramic brake pads, ended up ruining my stock rotors, didnt make my rims dirty(so gay)
-180 thermostat to run a cooler vehicle, but learning about a loop system and finding out that my mileage has gone down since, cutting holes in my hood for heat dissipation and installing vents off a Trans Am, winter time sucks when the heat just blows cold and take forever to heat up.
-Lucas injector cleaner works to clean out injectors, but plugged my #3 injector($56)
- bushwacker flares, broke one while taking out the box
-I am still torn about K/N cold air intake, how the hell do you find a replacement filter so yo can have one for trail and one for everyday driving?
 Post subject: Re: What I wasted my money on and it didnt work!!!
 Post Posted: Thu May 21, 2009 8:43 am
Online
I slid this into Misc 4x4 tech, as it is going to be highly informative to all 4x4 people. :)
Thanks for starting this post - awesome idea! :tu2:
 Post Posted: Thu May 21, 2009 8:46 am
Online
I'll add to this. On my sister's XJ, I used an external voltage regulator meant for a Dodge to bypass the PCM (she was having random weird charging issues). It never did charge properly - even after a new alternator & battery.
 Post Posted: Thu May 21, 2009 10:33 am
Don't run a K&N off road, just use a paper filter. The K&N will allow to much crap past it and into your engine. Plus as soon a a K&N gets wet, its useless, it will allow water and crude to pass right through. A paper filter will actually keep a small amount of water from going through. (K&N will allow a splash through, paper will stop a splash of water).
 Post Posted: Thu May 21, 2009 8:57 pm
Huge 2in lift shackles off ebay. Got me the lift i was looking for...at the cost of horrible steering and 2 bent leaf springs. Only had them on about 2 weeks or less before just giving in and ordering a lift.
 Post Posted: Tue May 26, 2009 10:21 am
My Ukranian mail order bride never showed up
 Post Posted: Tue May 26, 2009 4:42 pm
Has people been deleting funny stuff so if I said Portmanteau midget prostitute it will be gone?
 Post Posted: Tue May 26, 2009 4:46 pm
No, probably not because this is your thread. But you do have my undivided attention now! I've been looking for one of those for years! :eyebrows:
 Post Posted: Tue May 26, 2009 4:58 pm
wheel spacers what was i thinking! :doh:
jks quick disco's might be good for some people but no sway bars are better :tu2:
a/t tires :doh: (no offense to anyone wheeling them)
 Post Posted: Tue May 26, 2009 5:58 pm
yes...a/t tires bring the suck. I definitely don't like the no swaybar thing though. I've driven like that for a while, and haven't had a rear swaybar for a couple years. But with the way I enjoy driving I need that front sway bar on there. It's a race jeep...duh. Plus you can't pull a TJ wheelie with no swaybars.
 Post Posted: Wed May 27, 2009 1:43 pm
web wheeling is off the hook!!!
ima throw this one out there most allready know but some dont.... fix-a-flat or like tire sealants never ever use that crap. just plug it or take it in and get it repaired
Still just a kid that likes to play in the mud. My go cart is just a little bigger.
1991 cherokee, 3" bds lift (hers)
1987 comanche 4bangin 4x4 (stock for now)
2007 powerwheels jeep unlimited
 Post Posted: Sun Jun 21, 2009 8:03 am
Was that on an off road tire? I've used it on car tires with success. I'm sure the guy changing your tires doesn't like it.
 Post Posted: Sun Jun 21, 2009 5:05 pm
i used it on a car tire. and when you do go to get your tires changed ive heard of some places charging extra if you put that stuff in mostly cause its so freaking nasty to clean up
 Post Posted: Sun Nov 14, 2010 6:30 pm
3 dana 35's...
Users browsing this forum: No registered users and 9 guests
