 Post subject: problem with zj starting
 Post Posted: Sun Dec 03, 2006 12:57 pm
i guy i know has a 98 5.9 grand he is having trouble when he starts it when its cold. when he tries to start it the motor just cracks. but if he just stops cracking turns the key off and tries again it will fire right away.
has anyone ever seen this before. he had the coil pack check and stuff.
any help would be cool
1987 cherokee hacked up with front 44, rear 14 bolt, np231 to dana 300 doubler
1999 grand cherokee 2lift
 Post Posted: Sun Dec 03, 2006 2:13 pm
tell him to put a fuel pressure gauge on it the fuel pump is most likely draining all the fuel in the lines back to the tank and it takes a long time for it to get pressure and purge the air.
1991 Blue XJ 3"lift, 35" MTR's, Custom rockers, Lots of triming, Gutted and bedlined.
95 green ZJ wifes
93 green ZJ my spare
61 fc 170 flatbed project
 Post Posted: Sun Dec 03, 2006 10:55 pm
we will have to try that if the pressure is low would you change the fuel pump?
 Post Posted: Sun Dec 03, 2006 11:00 pm
or put in a dual battery system. :lol:
 Post subject: Re: problem with zj starting
 Post Posted: Mon Dec 04, 2006 1:57 am
what do you mean by cracks?
does the motor turn over? or does the starter try to turn but doesn't have the oomph...?
mac 'who turned the heat off outside' gyvr
 Post Posted: Mon Dec 04, 2006 11:02 am
Probably fuel pump check ball. New pump would cure it, but definetely check the pressure first. In my experience, the pressure shows barely below optimum, but a new pump fixed it.
 Post Posted: Mon Dec 04, 2006 5:25 pm
hey MAC i met the motor turns over but just did not fire. it has to be something in the fuel pump i think everything has been checked
thanks guys
 Post Posted: Mon Dec 04, 2006 11:35 pm
I was tired when i posted the first one so I could explain this a little put the fuel gauge on start it up bring it up to temp shut it off and and check the pressure, if the pressure drops more than 10 psi in 20 min or so put a pump in it. just so you know I was a dealership jeep tech for 11 years.
95 green ZJ wifes
 Post Posted: Tue Dec 05, 2006 2:37 am
if it turns and turns and turns and doesn't fire that i would check the fuel pressure. if the pressure isn't there then i would say that it is the fuel pump. fuel pumps are known to go out on grands. if there is fuel pressure then i would lean towards a cps...or a tps...but check that fuel pressure...
it could be a coil as well...does it sound like its going to fire at all? if you have fuel pressure and it sounds like its just on the edge on trying to fire then its almost a sure bet its the coil...just went through that on the big vangina at the end of the summer...
mac 'coiled up and coiled out' gyvr
 Post Posted: Tue Dec 05, 2006 8:28 am
greasy gizzard-juice
shoot a little bit of ether into the air intake when it's cranking if it fires on the either then it isn't getting fuel, quick and easy way to check if that's the problem. Only other thing that comes to mind would be an ignition module going bad possibly.
Check out my woman's webpage so she'll be happy lol. If ya need photography work done this is the place to get it.
http://iwant2shootu.com
