 Post subject: damm defroster
 Post Posted: Wed Dec 17, 2008 5:43 pm
in my ZJ doesn't switch to vents. If I had a warm garage I'd stick my head under the hood and explore a bit. Anyone have some insight on which vacuum hose operates it, so that I may investigate for blockages?
 Post subject: Re: damm defroster
 Post Posted: Wed Dec 17, 2008 9:39 pm
Not sure with ZJ but other vehicles I have worked on the vacuum hoses for the vents look about like 10g wire and they run into what will look like a wiring harness, should be under the dash somewhere.
They were even colored like a wire would be just fyi, look somewhere in the center probably around the middle vents. Like I said though, that is from other car type experience
2011 Dodge Ram
Air Assault!!!
Militaryjeepers.com
 Post Posted: Thu Dec 18, 2008 11:21 am
dad had to pull the dash on his and replace a bunch of vacuum line that had dry rotted over the years...
i'm tied up with garage space at the moment...possibly have some time and room sunday...
mac 'just another zj hvac mess' gyvr
 Post Posted: Thu Dec 18, 2008 4:50 pm
I got it fingered out. The vacuum line is about 1/8 inch and goes through the firewall near where the AC lines pass through. Maybe time, heat, and being bent like it was made it break. I fixed it with a little piece of hose from Advance Auto.
 Post Posted: Thu Dec 18, 2008 9:55 pm
2011 Dodge Ram
Air Assault!!!
Militaryjeepers.com
