Post new topic Reply to topic  [ 2 posts ]
 Post subject: power steering hose problem
 Post Posted: Fri Sep 24, 2010 9:22 pm
Power steering issues. The high pressure hose is leaking and to get a new on it askes if it has power assist or not. how do you know if you have it or not :crybaby2:
Have A Blessed Day
Dave<><
_______000_
/__l_l_,\____\,_
l_---l_l__l---[ ]llllll[ ]
....X........X........X
..(o)_)__(o)_)--o-)_)
Wheeling For Christ in a XJ
 Post subject: Re: power steering hose problem
 Post Posted: Sat Sep 25, 2010 8:51 am
if it's a 96 or newer limited then yes, it has variable assist steering. *EDIT* this is for an xj, not a zj correct? then no, i dont believe it has it, i believe it was only offered on the zj's. there should be a connector with 2 wires going to it on the ps pump if you do have it.
