 Post subject: NO SPARK???????????????
 Post Posted: Fri Sep 23, 2011 9:23 am
Ok so I just got a 97 ZJ w/ the 4.0 It cranks but wont start and there is no spark. So far I have changed the Crank Position Sensor because some of the wires to it were cut and also I have changed the cam position sensor (distributor pickup). I also switched out the coil with a known working one. Still No Spark. I've got power at the plug that goes into the coil but no spark coming from the coil or any other plug wires. Also its throwing a P0340 code which is the cam position sensor but I just replaced that with a new one ANY IDEAS??????????????????
1992 XJ; 6'' Lift ; 33's; The Trail Rig
2000 XJ; 4'' RC Lift; 31x10.50 BFG's; Roof Rack; 100 watt KC's
1990 Mustang GT; 5.0L Cobra Intake and Heads; 8.8 with 3.73's; 17x9/10.5 Cobra R's
 Post subject: Re: NO SPARK???????????????
 Post Posted: Mon Sep 26, 2011 9:22 pm
If its still throwing that code...then its probably still the issue.
mac 'disco the battery and let it sit all night?' gyvr
 Post Posted: Thu Mar 01, 2012 9:15 pm
If I remember correctly the cam sensor doesn't cause no spark issues, it's only for timing. Try the pickup in the distributor. Or recheck crank sensor wiring.
 Post Posted: Thu Mar 01, 2012 10:01 pm
the 2000 doesn't have a distributor, i'd say recheck the cam position sensor...
if it doesn't work after that, check the coil pack, you could also have a bad one.....
edit:
i believe the cam position sensor is supposed to control fuel timing, but it will cause it not to start...
